I am trying to get a 1974 15 hp back together. The last guy to use it sheared the flywheel key.. I replaced the key, but while I had it apart I took this chance to rebuild the carb. When I brought it home it wasn't running at all so I have no history to work from. Put the carb back together, set the needle valve out @ 1 1/2 turns and cranked. I can get it to run at high speeds in neutrl, but forget about idle. It just dies. Any suggestions?
