Re: is 92 octane non- oxygenated gas o.k to use
Trent! <br /><br />Sell you? Well, Im a dealer also, But I will not try to sell you on a product, just a TYPE of oil!<br /><br />I use it in two and four strokes, but we are talking two strokes here! I have been using synthetic two stroke oils for 25+ years in everything from MX motorcycles , weed eaters, chain saws, blowers outboards! Every aplication has had positive rusults and have never seized a piston over those years! Nor has anyone Ive sold to! Always had very clean pistons and bores! Dont buy spark plugs by the case, and have never Decarbed anything! A lot less smoke also! Most of these devices were run on regular 2 cycle oils first, so I new how they performed on regular oil first! Every aplication showed better overall performance! Cleaner, cooler, seemingly more power! In these applications, there is not enough cost difference to worry about! I gained enough extra RPMs in an 85 HP outboard to go to the next pitch prop buy changing the lower unit oil to synthetic and going to a synthetic outboard oil! Even I was pretty amazed by that one! Some have better off season protection also! I see NO reason to use anything else!<br /><br />I dont need a bunch of scientific proof about it, I just know it works!<br /><br />TC-W3 oil is fine,(But it is just an industry Minimum standard) it will not hurt your engines, but you will get better performance all around with synthetics!<br /><br />There are things to look out for, do not use a synthetic designed for air cooled engines in water cooled aplications and vice versa ! Unless they specify that you can!<br /><br />LubeDude
