Re: hydrofoil?
dansoph,<br /><br />No, your engine does not have an air filter, The housing on the front of the engine is just actually a silincer.<br /><br />You DO NOT need premium fuel. Actually, it is detrimental to an outboard. Premium fuels burn cooler, leading to deposits in the combustion chambers. Those deposits cause all kinds of problems, from sticking rings to glowing embers which cause detonation. Stick with the 87 octane.<br /><br />When you replace the plugs, make sure you use Champions. OMC's do not like any other plugs-for some reason.<br /><br />Also, what is your wide open throttle rpm? It should be at least 5500.<br /><br />What shape is your prop in?
