recently bought a 72 johnson 100hp hydro electric shift. water pump was supposedly replaced. i had to reattach lower unit to engine. having leaking problems. Quest: is it normal on this model to have a tiny hole on port and star sides approx. 1/16" dia. on lower unit in addition to the two **** holes underneath engine pan or could these be caused by electrolosis? these holes are a-symetrical on location of unit. with muffs on and engine running all water pressure seems to be escaping through these small holes and not making it to **** holes. also i have a hole where engine connects to lower unit portion facing the boat that i dont know if it supposed to be there. when engine is running water shoots out of this hole. after shutting engine off gear oil escapes. any suggestions?
