Having just had the powerhead rebuilt I was in the process of putting it back on and found two wires I needed help with. I don't remember exactly where they were and was hoping someone in the forum would know . They come off as one wire from under the flywheel (timer base I think) and go toward and by the #1 cylinder before splitting into 2 connections. They were connected by flathead screws to the top two posts on a rectangular wiring panel maybe 5" long and numbered 1-7, top to bottom. My problem is I can't remember which wire goes to which post (I think they are the same color, can check on that tonight) and I don't want to mess anything up before starting the motor. Any advice on the matter is appreciated - I have learned a good lesson and will make notes next time. Thanks. <br />Jeff
