  #1
Old April 2nd, 2004, 04:23 AM
mako231 mako231 is offline
Default 1986 Evinrude 225 shifting problem
It's a 1986 Evinrude 225 on a 231 CC 1986 Mako, went out last Saturday, after clearing the "The no wake zone", pushed the trottle down and got on plane at 5000 RPM's. Everything was fine and the boat was doing 30 MPH when after around 1 minute all of a sudden the engine shifted to neutral, but the trottle was still "forward" The engine was still running, water coming out of the pee hole. Turned engine off to check, could not see nothing wrong on the outside. No broken prop, no oil residue in water, no holes in lower unit/mid section. Shift rod still attached to cable and move up and down. Engine runs fine, but would not go into forward or reverse. Anybody have something similar happened to them, where should I start looking. Any help or suggestions are appreciated. Thanks
  #2
Old April 2nd, 2004, 04:32 AM
BrianTindall BrianTindall is offline
Default Re: 1986 Evinrude 225 shifting problem
Check the prop hub. You may have spun it. With the engine in gear try turning the prop. Does the prop shaft spin with the prop (problem inside L/U) or does it stay still (hub is spun)? Do you have a spare prop to try?
  #3
Old April 2nd, 2004, 04:56 AM
james roach james roach is offline
Sounds like you broke the drive shaft in your lower unit. I had that happen on my 1987 200 HP. You are probably in the market for a used LU. Hopefully you will prove me wrong, but I doubt it.
  #4
Old April 2nd, 2004, 05:36 AM
Thanks for the quick responses. Brian, I did try to spin the prop while in gear and it turns freely, although it's in gear. James, that was the first thing that came to mind when it happened, but I thought that if water is coming out of the hole, then the shaft most be turning, unless I am wrong. If it's in fact a L/U problem, where should I look at, the clutch dog, or the gears itself. Or maybe like you said, I should start looking for a used L/U.. Thanks.
  #5
Old April 2nd, 2004, 06:19 AM
Thats because it is broken below the water pump. The same thing happened to mine. Water pumped and everything. Not to fear though those LU's are all over ebay.
  #6
Old April 2nd, 2004, 06:24 AM
James, that makes a lot of sense! I didn't think about that.. Well at least I have an idea of what to look for this weekend when I pull the L/U out. Would you recomend to get a used L/U or try to repair this one. Thanks.
  #7
Old April 2nd, 2004, 06:58 AM
By far find a used one. I feel your pain. I was comming in from the ocean and when i hit the ICWW I wound it out. I decided to hit the trim button 1 more time and snap it went. Luckily I got it throttled down before the motor blew up. I had just purchased my motor used so the dealer I bought it from gave me a used lower unit.
  #8
Old April 2nd, 2004, 07:05 AM
http://cgi.ebay.com/ebaymotors/ws/eB...tegory=50 439 I dont know if I am supposed to do this or not.Great price on a used unit. Guaranteed 30 days I believe.
  #9
Old April 2nd, 2004, 08:05 AM
James, Thanks for all the advice, I will start looking for a used L/U then. Ebay and Iboats would be a good place to start. I need to move quick, Kingfish season is here already....
  #10
Old April 2nd, 2004, 08:10 AM
I just bought a mid section with TNT from a guy locally. He had the complete unit on eBay (2470465159 http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT). It's a '91 assembly. He still has the lower unit if you're interested. Email me at bdtindall2@comcast.net and I will forward his info to you.
  #11
Old April 2nd, 2004, 08:41 AM
Dave Abrahamson's Avatar
Dave Abrahamson Dave Abrahamson is offline
Mako,You could also check out Don's Marine Salvage over here in Clearwater to avoid shipping costs from an Ebayer. I go there frequently and he has quite the collection of pretty much everything.www.donssalvage.comDave
  #12
Old April 2nd, 2004, 08:49 AM
Dave, thanks for the info. I know where Don's shop is, I will pay him a visit since I work at MacDill anyway.
  #13
Old April 2nd, 2004, 09:04 AM
  #14
Old April 2nd, 2004, 09:21 AM
Maybe I'll see ya at work this weekend Should be a good showDave
  #15
Old April 2nd, 2004, 09:25 AM
Yes, you're right. The blue angels have been flying over our office all day... I believe they are doing a pre-show today for all the active duty families aboard the base.
  #16
Old July 16th, 2008, 07:41 PM
mirage5058 mirage5058 is offline
Hello first time trying to post something i put it here i have a 88 sylvian had a 88 johnson on it i put a 200hp evenrude now after hooking up cables it seems to shift fine but starts reving real high goes from a nice idle before shifting to a real high racing idle did i put cables on wrong? Or is it something else,any help would be appreciated,if i posted this in the wrong place im sorry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1986 evinrude 175 hp charging problem sweetmarie Johnson & Evinrude Outboards 3 October 5th, 2005 04:16 AM
1986 Evinrude 6hp Carb Problem ...Help wht89lx Johnson & Evinrude Outboards 1 August 26th, 2004 06:44 PM
1986 Mercruiser Shifting Grinding/Stalling Problem scotty boy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 5th, 2003 05:45 PM
68' evinrude 55 shifting problem voigto85 Johnson & Evinrude Outboards 1 June 4th, 2003 12:38 PM
68' evinrude 55 shifting problem voigto85 Johnson & Evinrude Outboards 0 June 4th, 2003 11:31 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
