Re: HD25 compression?
Hi McG,<br /> I am sure part of it is simple physics meets economics. A smaller volume would take much more energy to build up high compression. In a small fishing motor, high compression isn't necessary. Higher compression requires higher strength parts, which cost more money, which weigh more, etc. It also can put more stress on the motor and shorten the lifespan. Most fisherman are far more likely to buy a motor that will get them out and back reliably than one that might go a bit faster, but is more likely to break down or wear out quickly.<br />- Scott
