I need help!!!! 99 90hp evinrude will not run!<br />I pulled codes from diag unit and came back with low voltage and also crank sensor. I made necessary ck's of components and adjusted air gap on crank sensor but I can not clear those 2 codes.<br />Can anyone help me to get codes cleared and start this thing so I can go fishin'<br />I accessed codes, according to a manual, thru<br />the throttle switch and tried clearing codes acoording to manual but it does not work when you manually slide lever over on switch light on gauge<br />should come on and stay on and you are supposed to this several times to clear all codes. It will not clear mine though.
