I couldnt find it...its been a while since it was removed. 1983 70 hp evenrude
B boatin Petty Officer 3rd Class Joined Jul 20, 2003 Messages 84 Nov 9, 2003 #1 I couldnt find it...its been a while since it was removed. 1983 70 hp evenrude
snapperbait Vice Admiral Joined Aug 20, 2002 Messages 5,754 Nov 9, 2003 #2 Re: quick ?...is there a locknut under my flywheel nut? No lock nut... you need a flywheel or harmonic balancer puller to remove the flywheel..
B boatin Petty Officer 3rd Class Joined Jul 20, 2003 Messages 84 Nov 9, 2003 #3 Re: quick ?...is there a locknut under my flywheel nut? Thanks Snapperbait<br />I used a harmonic ballancer to pull it...works great. I just couldnt remember if it had a locknut when the time came to reinstall it
S Solittle Fleet Admiral Joined Apr 28, 2002 Messages 7,518 Nov 10, 2003 #4 Re: quick ?...is there a locknut under my flywheel nut? When you put it back together make sure that you torque that nut to spec.
