Mark42
- Oct 8, 2003
- 9,334
I checked out the control unit I have and it says "Johnson Command Center". I opened it up and there is a horn inside. There is also a grey tach wire with the end capped off with shrink tubing. Both ends of both cables match the pictures of the cables in the newer flat control box shown in my 1993 service manual. They also connect to the 1993 Evinrude 40hp ob I have just like the service manual shows. <br /><br />I would like to know the years that this Command Center was in use, and if it will self test, features and functions, etc.<br /><br />I have searched these forums as well as the net in general but have only found a few references to Command Center in posts at iboats, but nothing that addresses my issues.<br /><br />Thanks,<br /><br />Mark.
