1994 120 johnson looper. I've been having trouble with motor for about a year and its been getting worse. Now it will hardly idle at all. It started the trouble by sneezing when cold but running fine after warming up. Now it never stops sneezing (and its a hard sneeze with big puff of blue smoke). I've been thru the carbs several times and they are spotless. Idle mixture screws won't make it stop sneezing. Today I torn it down to the intake manifold and I found one reed block covered with carbon. I'm getting fire to all cylinders and compression is 110-115 on all 4. Am I getting crankcase detonation on this cylinder and if so, whats causing it.
