just bought a grady white with twn 1995 225 evinrudes. boat test great except tachs erratic and volt meters pegged out at 18 volts at 3500 rpm. found that the on board batt charger was putting 30 - yes 30 volts to the accessory battery and cooked it. the 2 eng readings were good. am no longer using the on board charger. -ill check for loose wiring but is this a volt/reg/rectifier issue? any experiance would be appreciated.<br />regards
