Re: 1987 johnson 120 hp
Never try to tune or adjust things on the muffs.<br /><br />Try setting the idle timing to zero degrees, top dead center, and run it in the water. Warm the engine up to normal operating temperature. If it idles too fast, retard it (ATDC). If it won't idle, advance it (BTDC). <br />Get it ideling well, and let Joe Reeves know what the timing at idle ended up to be.<br />Everything may be ok at the lake, not in the driveway on muffs. That's my personal experience.
