Re: need all you got?
Don't believe there are points, but compression is relative. At least 100 PSI and within 10% of each other is a good starting point. The fuel mixture is 50:1. About 2.5 ounces TCW-3 oil to 1 gal. gas. If it has points, the gap is .020. Plugs are QL86C or L86C, gapped at .030.
