Re: Boost 150HP to 200 - 225?
That is a good suggestion. It will increase your rpm up to a better spot than the 4 blade.<br />I really like running my 200 at 6000 rpm at WOT.<br />When I back it down to 5500, I am at a efficient throttle setting (gas mileage), and engine just purrs.<br />Try to get your WOT rpm at the top of the range.<br />You will be happy.<br /><br />I think you could get a 15" pitch 4 blade, but you will definately lose top end speed, but your rough seas performance would be top notch.<br /><br />Prop selection is a big compromise, but my suggestion is to "rev it up"!
