Hello,<br />I took my Johnson J4BRHCT out yesterday for a test run. Everything was fine for about 20 minutes and then I the motor stopped and could not be restarted. Upon inspection I noticed the intake port (or what I believe to be) on the front side of the shaft was blocked by some sea-weed. <br /><br />My question is, how much damage have I done to the engine? <br /><br />Also, how much water should be coming out of the six ports in the back of the shaft? I never noticed more than a trickle.<br /><br />Thanks!<br />Mo
