Winterizing an outboard?
Bearcamp
What's the correct way to winterize an outboard. I know it possibly could be a problem setting outside in the cold winter months. But mine will be inside in the warm. How do you winterize it either way?
crazy charlie
Re: Winterizing an outboard?
Get a manual and follow it .It is quite easy to do.Flush it,fog it,change lower lube and grease hinge points and steering.store with the steering pin in the full out position. charlie
