jtwood2780
- Oct 5, 2003
- 2
I have a 1958 Evinrude Fisherman 5.5HP OB motor. I have what I think is the original pressure tank for it. I can get the motor to run in a test tank but it will die out after maybe 15-30 seconds if I don't keep pumping on the primer button on the tank's top. Does anyone have any suggestions about where there are typically a common point of failure with this type of problem? What areas of the fuel delivery system should i concentrate on troubleshooting? Thanks for any help you can offer me.
