KillerJello
- Aug 17, 2003
- 52
Im having a bit of trouble with this motor (Evinrude StarFlight 90-S, Model:904935 Serial:E05923) getting the powerhead off.... I have a Seloc service manual (only one the local dealer had) <br /><br />The manual says to remove the bolts in the front and rear of the powerhead securing the powerhead to the exhaust housing.... I can see a couple of the bolts (they are directly on the bottom, and theres a seam right????) but how in the world do you get some of them out, i can get to two, but the other ones are pretty much impossible. I have a complete set of tools (over 3000 peices, not including air tools) and i have tried everything... Are there any tips at all on how to get it off the lower unit? <br /><br />Basically the motor seems seized up, though the internals look brand spanking new, even the ehaust, no carbon or anything. The motor was sitting in a field for a couple years, so i suspect something is just stuck. The lower unit is less than 4 years old, and the motor looks brand new except for the chewed up wiring from the mice which i am replacing...<br /><br />The starter cant turn the motor, neither can a flywheel turner, even with the plugs out. The cylinders look brand new, no scoring or anything, and theres just no evidence to suggest that the engine is seized up, besides the fact that i cant get it to turn. <br /><br />I plan on rebuilding this, but its kind of hard working on it with the motor still mounted to the lower unit.<br /><br />Thanks in advance for any help you can give me.
