I am still having problems with my 1970 40hp Johnson. I am alittle lost. There are droplets of water on the lower cylinder spark plug (causing power from upper cyl only) but compression is good at 120psi in each cyl. I removed the head and there was white cloudy fluid in the lower cyl but no water under the side intake plate. There were no apparent leakage points on the cyl head gasket either. Where can the water be coming from? (Cylinder walls and piston heads looked excellent)
