Re: 1984 150 crossflo
OMC did not manufacturer a 200hp in 1984, however the eariler 200hp crossflow blocks would interchange. Look on top of the block, on the port (left) side near the head gasket. There should be a core plug there (looks like a small quarter sized freeze out plug) that would have the model number on it.<br /><br />If it's there, get the number to us and we'll tell you what it is.<br /><br />Note that even if it is a 200hp block, in all probability you're using your original 150hp carbs, intake manifold, etc etc so you're really not going to develop 200hp. Usually a swap of that kind works out perfectly so don't go jumping to any negative conclusions. He may have performed a favor to you. Let us know what you find.
