I've got a mid 70's motor, and when I try to start it, with the electric choke solinoid, the choke plates fluctuate when the starter is engauged, meaning that they don't totally stay closed while cranking the motor over. There is a spring attatched to the choke solinoid, allowing for the chokes to open up a bit while cranking the motor over. Is this normal, or do I have to hard-wire the choke seloinoid to the choke linkage to keep the choke flaps totally closed? Thanks, PDS.
