Combustion trouble on Ficht 115
ThDu
Thanks in advance for your help! During summer vacation, some combustion troubles occurs on my 2001 Evinrude Ficht 115. It seems that there are too much oil in the cylinder, the symptom is :<br />after a maintenance, RPM max is 5400, no trouble for 1 hour. After that (1h30 min ), the max rpm decrease to 4500 rpm (with same load) and its impossible to reach more rpm! The boat is sent back to the Evinrude repair center, 400 € for a maintenance, fixing the trouble ( reset ECU, new software, new spark plugs). Bingo, it works for 1h30 after that, again trouble and dame symptoms as before. Did anyone got the same troubles ? Did you have any idea of the root cause ? I need a motor in which I'm confident (dive boat, sometimes one boat on sea..) ? Thanks, Thierry, Belgium's diver.
sodinda1
Re: Combustion trouble on Ficht 115
I am having the same problem on my 2000 Evinrude Ficht 115. Have you heard of any solutions? Thanks :confused:
Solittle
Go to the red search at the top of the page. You may find info there.
nwox
have you solve??? I've the same problem please reply!
