Trim/Tilt
EvinFla
On my 1995, 115 Evinrude, my hydraulics go down, but not up. When the up trim is pushed, I can hear an intermitant clicking noise coming from a box toward the upper back of the engine. This is where the trim/tilt wiring leads to. <br />Any suggestions?<br /><br />Thanks all
Joe Reeves
Re: Trim/Tilt
Inside that box is two relays. Switch the position of the relays. If your problem is now the complete opposite, you have a faulty relay.
EvinFla
Re: Trim/Tilt
Thanks Joe,<br /><br />Excuse my ignorance, but are the relays the little boxes that are side by side in the box. And to check them should I disconnect the wires from both and reverse them. Thanks again, I'm obviously new to outboard repair, and appreciate all of the help.
roscoe
Re: Trim/Tilt
The relays are about an inch+/- square, with 4-5 wires going into them.<br /><br />One controls the "up" and one controls the "down".<br />If you swap the 2 relays, the motor should only go up, and not down.<br /><br />This will tell you that one of the relays is faulty and needs to be replaced.
Joe Reeves
Re: Trim/Tilt
Evin.... Yes, that's the relays. The wires aren't seperate wires but rather all are joined into a socket ie the relays plug into a socket assy.
