Re: 1974 Evinrude 115 Starflite won't idle in water
Hi Easy....welcome to the forum.<br /><br />Don't know how long you've had the engine but it sounds like either a carb problem or the sync and link is outta whack. The sync and link syncs the throttle and timing.<br /><br />If you don't when the carbs have been overhauled, it would be a good idea to do so. The low end jets may be plugged or you have some junk floatin' around the bowls.<br /><br />First advice to any boater planning to do his own work is to get a manual. They pay for themselves in the long run.<br /><br />Other things to do, check compression. The cylinders should be with in 10% of each other. 90psi or higher is considered good.<br /><br />Check the spark. If you can rig a spark tester that can be adjusted to a 3/8 to 7/16 gap, and hook your plug wires to it, the spark should jump the gap WITH the plugs still in. The spark should be very strong and a blue/white in color.<br /><br />If ya can, give us a little history on the engine, how long you've owned it, last tune up, stuff like that. It helps to know as much as we can so we can help. <br /><br />Thanks.
