The corner of the piston being knocked off at the exhaust port is usually caused by shock waves created by pre-ignition/detonation. Carbon build up on the piston dome could be the cause. So could an out of time ignition (too much advance, duble firing etc.) Coking usually causes the rings to stick in the ring groove and as the piston loses support the ring end is sheared off. Not necissarily next to a port.
The corner of the piston being knocked off usually happens near the exhaust port as that is the hottest area on the piston dome.
There is a reason for the piston damage. Something caused it. The corner did not "fall" off by itself. The cause must be identified and corrected so this does not happen again.
Good luck!
