  #1
Old January 17th, 2004, 01:17 AM
dcolpitts dcolpitts is offline
Default 140 evinrude exhaust port modification
the motor is a 1986 140 evinrude, when the boat sits in the water the exhaust port is about 1-1/2 inches above the water. The motor does not like to idle after 5-10 minutes, starts to load up. Have rebuilt cars checked and replace jets to factory specs, new vro pump,and elecs up to spec. Motor rus great other than this idling problem. I heard somewhere that you could drill or modify the exhaust port to help. Anyone have any knowledge on this. Thanks
  #2
Old January 17th, 2004, 01:32 AM
OBJ's Avatar
OBJ OBJ is offline
Default Re: 140 evinrude exhaust port modification
I remember the post okam but don't remember what it said. Try a search. Should be around here somewheres.
__________________
When in doubt...use the manual
Rayland, Ohio....Along the Muddy Banks of the Mighty Ohio River.
  #3
Old January 17th, 2004, 07:32 PM
walleyehed's Avatar
walleyehed walleyehed is offline
Keep your engine trimmed level, and gap your plugs to .040. for Idle. Drilling the holes clear through the exhaust chamber will decrease back-pressure, but that's not the way to adjust your Idle.EDIT: Exhaust PORT, is in the cylinder.......part of the block.
  #4
Old January 17th, 2004, 11:39 PM
seahorse5 seahorse5 is offline
With the motor sitting that low, there is more backpressure and the motor runs rich.Make sure each cylinderhead temp is close to 140 degrees at idle, you may need new t'stats. Use the Champion QL82YC which is a shade hotter, less fouling, than the QL78YC that is recommended for normal use. Run a carbon cleaner such as Engine Tuner thru the motor a couple of times to help eliminate the built up carbon, but more importantly, clean out the fuel recirculation valves, hoses, and fittings. Use the correct service manual to adjust the carb needles. You might start by turning each one clockwise about 1/2 turn to see if she idles better.If you feel uncomfortable performing these checks, find a QUALIFIED tech that knows these V4 loopers.
  #5
Old January 18th, 2004, 02:58 AM
Update on motor status, The recirc valve and hoses have been cleaned and checked. The plugs which I think are recommend are champion QL77JC4 and are gapped at .040. The t'stats are the black ones, not the white. The boat has the water pressure gauge, but no head temp, I saw a post here about 2 sending units one on each head with a gauge and and a switch to go from port to starboard heads, I guess try that route can't hurt. Any other ideas would be appreciated, thanks for the replies
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Low Water flow from Port Side of gimbal Housing and Port Exhaust Elbow hot. roorancher Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 2 January 30th, 2007 10:11 AM
exhaust relief hole modification phatmanmike Non-Repair Outboard Discussions 4 December 28th, 2004 05:55 AM
Exhaust relief port on 1973 6hp Evinrude? steviecops Johnson & Evinrude Outboards 3 October 8th, 2004 02:26 PM
Exhaust port curiousity JStutz Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 September 27th, 2004 08:42 PM
Exhaust port modification -1994 Evinrude 120hp Digdug Johnson & Evinrude Outboards 2 February 26th, 2002 07:24 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
