I own a Johnson 25 model #J25TELCEM and when it idles or is running at low RMP no water comes out the water pump exit tube. It looks like steam is coming out instead of water. When I increase the RPM a little, then water starts coming out and it is initially super hot (almost boiling hot). When I run it at normal use RPM's, the water stream is steady and the water coming out is luke warm.<br />Does this mean something is wrong with the water pump or is this normal. I don't want to overheat the engine if this is not normal.<br />Thanks,<br />Bill
