I have a 96 Evinrude 200hp Oceanpro that I bought used a couple of months ago.<br /><br />The enging will idle forever when running on the hose with the ear muffs, but sometimes intermittently when in the water (load on prop I assume is the difference..)it will stall when in idle neutral as well as when it is idling just in gear.<br /><br />It seems that this happens only after the engine is warmed up, when I first start it it idles fine (quickstart bumping the revs up?)<br /><br />sometimes in gear I have to bump the throttle just slightly (just under 1000 rpm) in gear when I hear it trying to stall.<br /><br />Apart from that the engine sounds an runs good at any other setting.<br /><br />The VRO is disabled and I run premix(decarbed and changed plugs 20hours ago)<br /><br />I have yet to adjust the linkage and idle<br /><br />Do you think this would cure it? or should I be looking into the carbs?<br />What should be the idle in neutral and just in gear? (mine idles at or near 800 rpm and that drops to 600 when I put it in gear)<br /><br />Thanks in advance for you input, it is much appreciated.
