  #1
Old January 7th, 2004, 03:47 AM
cacioa cacioa is offline
Default 1973 6HP Evinrude Broken Pinion Gear
I transported the motor from NY to FL to find out when I got to FL that the Pinion Gear broke in 1/2. Right where the Roll pin slot is. Therefore I have nothing engaging the flywheel to start the motor. The Starter rope, when pulled, coils back perfectly. Does anyone know if this is a hard part to replace for a non mechanically inclined person? Or should I just pay a shop to repair the part. -I cant Imagine this job costing too much.ThanksAnthony
  #2
Old January 7th, 2004, 04:59 AM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: 1973 6HP Evinrude Broken Pinion Gear
Cacioa.... The term "Pinion" pertains to the gear in the lower unit which is attached to the driveshaft.The gear that you are speaking of is a "Manual Starter Bendix Gear", or simply "Bendix Gear". The OMC part number for that gear is 318447 and cost approximately between $10 to $15.It's not difficult to remove and install but the manual starter must be unwound before removing the retaining pin, otherwise the spring will unwind violently when the pin is removed. Good luck.
  #3
Old January 7th, 2004, 05:03 AM
Joe, Thank you very much. This is very helpful.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude pinion gear cullracing Johnson & Evinrude Outboards 2 August 15th, 2006 09:59 AM
Starter pinion Gear on 1989 Evinrude 88 horsepower motor Bobby Autry Johnson & Evinrude Outboards 0 August 10th, 2006 08:39 PM
Pinion gear needed 40 hp Evinrude Merrill Johnson & Evinrude Outboards 1 July 23rd, 2005 06:27 AM
86 Evinrude 15hp Pinion Gear Spring?? imported_Warren Johnson & Evinrude Outboards 4 November 22nd, 2003 07:12 PM
1981 Evinrude...... 7.5hp lower unit pinion gear MikeMoonpie Trailers and Towing 1 August 17th, 2002 06:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
