What Year & Help please
Fat-Boy
3HP Johnson Model JWF-22C<br />Serial # C543411<br />Is This Water Cooled or Air Cooled<br />Just Purchased: It starts but only for a few seconds and dies out: It has a lean and rich selector knob but no stopper so I do not know where the setting is at. I put in new plugs and a new gas line hose and checked the float bowl. The bow was spotless: Any suggestions. Thank you !!
bubbakat
Re: What Year & Help please
1967 JH-JHL-22 <br /> JHF-21 <br /> JHF-22 <br /> JW-JWL-22 <br /> JWF-21 <br /><br />The only other model number i found with jwf was a jwf 23 made in 1968<br />it is water cooled an if indeed a 67 or 68 the mix would be 50:1 and plugs would be J6C gap at 30<br />put the mix knob about half way and pull out choke and start release ck and let warm up and then adjust knob as needed to smooth out idle.<br />not necessarily the slowest idle but smoothest<br />hope this helps
Fat-Boy
Thanx Bubbakat for the quick reply. The problem I am having is that when it starts, it only runs for about 3 seconds, I put the choke in and it does not help. On the mixing knob the knob just keeps going around. I do not know if it is open or closed as there is no stopper to stop the dial from going all the way around which it is doing now. The guy I bought if from said it has been about 16 months since it was last started. I emptied all the old gas and replaced it at a 50 to 1 ratio. What do you think? Any other ideas on what the problem may be.
Xcusme
Fat-Boy,<br />A motor that starts and then quickly dies usually points to a fuel delivery problem. This can be a low speed idle knob out of adjustment, dirty carb (low speed idle circuit), mis-adjusted float level, bad fuel pump. <br /><br />Remove the cover and see if the idle adj. needle shaft is turning when you turn the knob. Sometimes the knob will spin , but the shaft of the needle does not. If the shaft does turn, turn clockwise until it lightly seats (closed), then turn open (counter-clockwise) 1 1/2 turns. Adjust per destructions below. :D <br /><br />(Carburetor Adjustment - Single S/S Adjustable Needle Valve)<br /><br />Initial setting is: Slow speed = seat gently, then open 1-1/2 turns. <br /><br />Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.<br /><br />Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting. <br /><br />When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.<br /><br />If the above adjustments does not allow the motor to continue to run, it's time to take a closer look at the carb ( through cleaning etc).
bubbakat
pull the carb and clean it .I have a 7 h/p that set for about 6 months and the float stuck in the almost close pos. therfor no fuel. then adj as xcuseme says
Fat-Boy
Thank you very much for all your input and helpful advice. Now I have something to work with.
