I have a 48 gallon fuel tank that the fuel guage registers full all the time. I pulled out the sending unit and moved the float up and down and the guage and the unit registers fine. I put the unit back in and slowly moved it up and down and everything registered. I checked for obstructions in the tank and screwed the unit back in (poly to poly). It still registers full no matter what the level. I tried to recreate the possible flexing problem but could not find a problem. The tank is mounted in a 21' center console cajun fishmaster. Any suggestions? Thanks.......Wes
