Specs for 1969 2-cyl 40 hp Johnson Electric motor
mmaddox
I would appreciate the following info if anyone has it for a 1969 2-cyl 40 hp Johnson Electric motor:<br /><br />Fuel mix ratio:<br />Ignition:<br />Points setting:<br />Plug type & gap:<br />Compression range:<br /><br />Any other good stuff.<br /><br />Appreciatively,<br />Mark
LAKESIDE MARINE
Re: Specs for 1969 2-cyl 40 hp Johnson Electric motor
spark plug:j4c point gap:.020 fuel oil ratio:50:1 compression not sure just make sure it is no more than 10 psi. difference should be 70 to 120 psi. or so.
