Re: JOHNSON F/S 150 TO 175
1998 Stratos 283VR with 93 150 Jonny faststrike (boat is rated for 175)<br />no feed back Teleflex steering 5.5 set back CMC Hydraulic JP vertical adjustment: prop shaft even with pad to 6 below pad. Motor has approx 70 hours on it since new. Boat was new motor was in a show room display. Bought as a bank repo. Boat and motor run exec. <br /><br />1990 92 John GTs had 175-200 hp till they got caught tampering 93 back to 150 (this may not be exact dates and rating but its what I heard).<br /><br />Props: 14.5 x 22 Raker 5600 rpm 58 speedo<br /> 14.5 x 24 Raker 5200 rpm 61 speedo<br />hand held gps wasnt accurate (by time I get back to dock speed still going up) but test were same conditions for speedo readings.<br /><br />Yes I agree with you that bore, stroke & gear case ratio (1.86:1) r the same but an addition <br />25 hp could yield the following:<br /><br />Not taking into consideration prop slip, pad design, gear ratio and weight of boat for actual speed results Ill use this as an example:<br />22 Raker at 5500 rpm = 121,000 i.p.m.<br />23 tempest 126,500<br />24 Raker 132,000 8% gain<br />25 tempest 137,000 12% <br /><br />The extra 25 hp and more torque should allow me to run a larger pitch prop at the same rpm and increase speed.<br /><br />If I were to purchase a newer 175 @ x 1,000s of dollars I think it would enhance my need for speed (if I had da money Id buy a Alley, Bullet, gambler or stroker With the 250/280 conversion and go 100 but I have to stay on the porch for now).<br /><br />By the way I was beaten by a 28 Playcraft Power Toon pontoon boat last week, at first I cried but now its a funny story to tell. He had twin 250 modified hpdi yamis on it. Went about 75 mph. <br /><br />My question is if the 175 has the same cowling, gear case, powerhead, etc. what makes up the 25 hp dif ? And also if you know how did the 90 ish 150 have 175-200 hp ?<br /><br />p.s did ya think about the exhaust porting and the straight pipe idea <br /><br />thanks Jeff braaaaaaaaaaaaaaaaap
