  #1
Old December 23rd, 2003, 06:06 AM
bcomer bcomer is offline
Default Starter drive (bendix) 85 HP 1978 Evinrude
The drive on my starter sometimes does not engae properly (just whines). Therefore I am making an assumption that the drive is falling. When this happens on an automotive starter you can just chnage the drive unit if the starter and solinoid are good.Where can one buy just a bendix drive for these starters? I have found starters without drives and complete starters but not just the drives.
  #2
Old December 23rd, 2003, 06:20 AM
dk990496 dk990496 is offline
Default Re: Starter drive (bendix) 85 HP 1978 Evinrude
Before going that far I would suggest you check your battery a low voltage battery will cause the bendex not to rise properly
  #3
Old December 23rd, 2003, 06:23 AM
The problem is intermittent and occurred even after installing a new battery with clean cables and connects. Also lubed the bendix shaft with WD40. Problem still happens.Where can I buy just a bendix for this starter>
  #4
Old December 23rd, 2003, 08:16 AM
Knightgang Knightgang is offline
Put a meter on your battery cables and be sure they are not corroded inside. The ends can look nice and clean and be terrible about 1/2 way throught the cable. Having resistance in the cables will deduce the amount of juice going to the starter and could cause the BEndix not to engage.Not sure if you can buy just a Bendix for one of those starters. I would check the least expensive options twice before trying to find the Bendix or buying a new starter.Knightgang
  #5
Old December 23rd, 2003, 08:20 AM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
The bendix drive can be purchased at any Evinrude/Johnson dealership, or possibly at NAPA, and also at third party suppliers such as Sierra.The OMC part number would vary depending on whether you have a Bosch or Prestolite starter as follows:Bosch = 386949 = Approx $20.00 (Available)Prestolite = 386102 (original #) superceeded to 391091 (Latest #) = Approx $60.00 if you can find one (Unavailable since 1998). Good luck.
  #6
Old December 23rd, 2003, 11:09 AM
JasonB JasonB is offline
My '76 did the same thing. Every few turns of the key, he bendix would actually engage. Replaced it and all has been well since.
  #7
Old December 24th, 2003, 10:26 AM
Thnaks Jason. That is exactly what mine is doing. Sometimes it cranks right up and other times it may take as many as 10-15 turns of the key to finally get the drive to turn the motor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
bad starter? bendix is spinning shelikesit Mercury & Mariner Outboards 0 October 9th, 2006 04:58 PM
1978 1150 starter bendix prob sundog Mercury & Mariner Outboards 1 November 14th, 2003 07:12 AM
merc 650 starter bendix RIDEPATE Mercury & Mariner Outboards 1 June 22nd, 2002 03:30 PM
starter bendix V156 Other Outboard Brands 7 June 19th, 2002 02:06 PM
starter bendix V156 Other Outboard Brands 1 June 17th, 2002 10:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
