Re: Wiring Diagram for 115 Johnson
You can put all of the adapters kits that OMC has, but if it does not have a tan wire from each sensor to the tach, it will not work. The wire colors are tan/yellow from VRO to tach. Tan from temp sensor to tach, tan/black from remote tank to tach, tan/orange from fuel restriction sensor to tach. You realy need to look at the engine and boat to see what you have for wires. I would check the control harness at the control and look for the 4 tan wires, if you have the 4 tan wires, I would say you have system check wires from engine to control. Then look for the tach connector in the rats nest of wires that most boats have. If only one tan wire, you will need harness 176*** depending on length of harness. The you will have a problem connecting to the ignition switch and the tilt/trim switch. I would cut and splice the wires to ignition switch and t/t switch. This way you will only need one harness, and old style ignition switch, which is the better switch. The other switch had one recall and one service bulletin for problems.Then you will need new alarm horn with harness connector.
