oldmanarkie
- Sep 1, 2003
- 1
I have a 1992 Evinrude 6 cyl 150 hp and after a 2 year storage without draining gas. I have sinse drained the tanks, put fresh gas in one and have worked the new gas up to carbs/injectors. I am not sure what they are but cannot get gas/oil mix into cyl's. The new plugs are not even wet.<br /><br />How do I clean carbs/injectors?<br /><br />What is the air valves behind carb cover. Looks like a tire valve. Is it used to blow air into engine?<br /><br />Thanks<br />arkie
