71 evinrude 100 ignition swap?
river rat 26
every thing i've ckecked on this ign. is looking bad, amp, coil, points, rotor, dist.cap etc. I have a 75 85hp parts mtr.,any chance all the ignition parts could be swapped out?
ledgefinder
Ensign
Re: 71 evinrude 100 ignition swap?
Sorry, 1973 and newer is a completely different system. 1969-1971 85 & 100hp V4 ignitions are exactly same as yours. The other 1969-72 V4s had a very similar ignition with a sensor coils (instead of points) and a different amplifier. The other system will also work on yours, if you swap everything.
river rat 26
thanks ledge, i kind of figured.......guess i'll start searching for parts. looks like the amp is gonna be some serious bucks.
ajp
River rat,<br /><br />What electrical parts do you have for an 1975 85hp Rude? I have a 1974 115hp and need a stator and power pack. Would also like to buy the ignition coils. Do you have this electrical system and would you consider selling it?<br /><br />If so email me at arlan@pldi.net<br /><br />Arlan
river rat 26
ajp, i've got it all but have an identical mtr. on my houseboat and would like to keep it for spares and troubleshooting purposes. the reason i wanted to swap out the ignition on the 100 was all this stuff is readily available and easy to work with. i'm probably just use to it,but it seems like a walk in the park compared to this antique bs on the 71. i'm gonna get it though, can't miss with the great folks here on this forum. what a wealth of knowledge. I'd have purchased a new mtr long ago if not for their help....river
ajp
I also have a 1969 Johnson 115hp. I am trying to get a 74 Rude 115hp going. Not sure which I will keep. I am thinking the manual shift will be more reliable for the long haul. <br /><br />Arlan
