  #1
Old November 22nd, 2003, 02:47 PM
imported_Warren imported_Warren is offline
Default 86 Evinrude 15hp Pinion Gear Spring??
The pull starter on my outboard keeps getting harder and harder to engage. I used to be able to pull the rope really slow and easy and it would start. Now I have to stand up and pull as hard as I can to get the pinion gear to move up and engage the flywheel. I see the pinion spring in there but can't figure out how it works. The seloc manual is no help on the problem....Any suggestions? Do I grab it with pliers and bend the spring in or out?......Thanks Warren
  #2
Old November 22nd, 2003, 06:01 PM
backdraft backdraft is offline
Default Re: 86 Evinrude 15hp Pinion Gear Spring??
Warren, there is a long u shaped piece of wire about the thickness of a coat hanger which slips over a upright piece of metal while the other open end slips onto the bottom of the plastic gear which jumps up and engages the flywheel. They sometimes fall off. You then have to pull real fast to cause the gear to jump up.. A lot of times they are laying in the housing somewhere. Hope this helps. nevjb
  #3
Old November 22nd, 2003, 06:37 PM
Nev, the U shaped wire is still there. Its in one piece and is placed under the starter gear. Do these things wear out? I stared at it for over an hour today while looking at the manual and just can't figure it out.....Anyone??????
  #4
Old November 22nd, 2003, 06:49 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Warren.... That spring, retainer, friction block, whatever one might call it, must be setting in a groove that is built into the bottom portion of that gear. If it's simply setting under the gear, it has no effect.Sort of like a fan belt must be in the groove of the pulley to do any good, simply being in back of the pulley does nothing.
  #5
Old November 22nd, 2003, 07:12 PM
Thanks Joe, I'm goin to the garage right now to look for that groove....Warren
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude pinion gear cullracing Johnson & Evinrude Outboards 2 August 15th, 2006 09:59 AM
Starter pinion Gear on 1989 Evinrude 88 horsepower motor Bobby Autry Johnson & Evinrude Outboards 0 August 10th, 2006 08:39 PM
Pinion gear needed 40 hp Evinrude Merrill Johnson & Evinrude Outboards 1 July 23rd, 2005 06:27 AM
1973 6HP Evinrude Broken Pinion Gear cacioa Johnson & Evinrude Outboards 2 January 7th, 2004 05:03 AM
1981 Evinrude...... 7.5hp lower unit pinion gear MikeMoonpie Trailers and Towing 1 August 17th, 2002 06:30 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
