crollinjones
- Aug 29, 2003
- 2
I inherited an Evinrude 18 Serial 18102SC 86865. The starter cord unit is held in place by three bolts. Two of the three holes are stripped. The bolts were laying loose in the housing with the hole threads on the bolts so I assume the holes are pretty smooth at this point. I found all but one washer - can it do damage if it falls in the wrong place? <br /><br />Should I drill and tap oversize bolts? Or use helicoils?<br />Thanks
