Re: VRO, Problem or Not???
Charles,<br /><br />Have there been VRO related failures-sure.<br /><br />However, let's look at what some folks THINK is a VRO failure.<br /><br />1. One or two cylinders fail. VRO cannot be cylinder selective. If one cylinder, destroys itself, that is NOT VRO.<br /><br />2. Engine seized, lack of lube. Water/crud in the VRO tank is not a VRO failure, that is a lack of maintenance failure.<br /><br />3. Engine seize. People ignoring warning horns.<br /><br />4. Engine seize. Oil line pinched, cracked.<br /><br />This system has been maligned more than second hand cigarette smoke.<br /><br />If maintained, the system works quite well and is reliable.
