SkipperSid
- Aug 25, 2003
- 1
While backing in shallow water with the motor partially tilted up, I had to get a bit aggressive due to high current. While revving to back out of trouble, the motor appeared to drop a few degrees (to about full down). When I tried to lift it, it wouldn't budge, & I heard no tilt motor sounds, either. Odd thing was, when I pressed the tilt down button, the tilt motor ran. It now won't run 'up' from either the control- or motor-mounted up button, but I still get noises when press the 'down' button. Any suggestions?
