Here is the drill: I have twin 1987 OMC 1.6L V4 SeaDrives on a 23' Wellcraft CC. I put it in the water today and futzed around for 20 minutes or so at no wake speed. Go to put it up on a plane and as it is climbing the step the starboard motor reves up to 5000 rpm, the port to 3000 rpm. When it gets up on the step the stwbd to 5500 rpm - the port to 4000 rpm - - after maybe 15 seconds the overheat horn goes off on the port motor. I shut it down and putzed back to the ramp on the stwbd motor (thank God for twins).<br /><br />Now the background - I run pre mix having the VRO removed when I got the boat 9 yrs ago. Water pump was replaced on both motors a year ago - water pressure on both motors at idle is 10 lbs and when on plane (for the short period before the horn went off) both motors were at 20 lbs. Good water flow from the telltale on both motors. Replaced the thermostats on both motors 6 months ago.<br /><br />Spark tested OK and compression tested (110 lbs +/- 5). Timing recently adjusted. New plugs & wires on port motor since last run. Cleaned & rebuilt the carbs on port motor this weekend. SS props with no nicks or bends.<br /><br />I fresh water flushed both motors (I run in salt water all the time) when I got home and nothing seemed out of the ordinary.<br /><br />I called the mechanic I use when I'm stumped & he wants to meet me this week on the water for some tests. He mentioned timing & a leak down test (I don't really understand what that is).<br /><br />Any ideas on what is going on or suggestions?
