Re: 65 Evinrude 9.5 Horse Starting Problems
Hi Wolos,<br /> You should be running a 50:1 mix in your motor, using good quality TCW-3 rated oil and mid-grade (89 is fine) gasoline. 87 octane may be good, too if it lacks added alcohol...<br /><br /> Did the motor simply do this once or is it a regular happening? Might it have overheated? A hot motor may lock up initally then free itself up after cooling down.<br /><br /> It's also possible you've vapor locked. If the gas tank is in the sun it may build up pressure inside, enough to force fuel by the float needle and into the intake. If a piston is below the port opening, fuel may enter the combustion chamber and puddle in the cylinder. It won't compress when the piston moves up. This can also happen if the float needle is worn or gummed up.<br /><br /> How did the motor run after you got it going? Was there any evidence of excessive fuel on the water?<br /><br />- Scott
