I have a 1999 90hp Evinrude fuel injected motor<br />that I am having trouble with. I changed the fuel and the fuel filters on my boat and now it will not run. I have spark and it will run if i spray starter fluid in it. It appears that I lost my injectors. Do I need to bleed them? or do I have something else going wrong here (relay, control unit, or some kind of sensor)? Any help would be great! I need to go fishin'The primer bulb is fine and I have fuel pressure after the fuel filter, just not getting fuel out of the injectors<br /><br /> vogelkna@bellsouth.net
