SteveJohnson
- Aug 18, 2003
- 2
I've got a 1984 Johnson 115 V4 VRO engine. It had been sitting idle for several years after the normal winterization stuff.<br /><br />Recently I cleaned it up, replaced the impeller & housing and put in new thermostats. It started right up and ran quite well at all speeds for maybe 8 hours.<br /><br />Then it started stalling at at high speed. When first started it runs normally for 5 minutes or so, then just cuts out like I turned the ignition off. No sputtering or anything - just cuts out. It easily restarts, but stalls again after a few seconds at speed. At low speed it runs forever - over three hours getting back to dock at 6 knots when this first happened.<br /><br />The temperature sensors seem OK, the warning horn is working, no indication of overheating. Happens with two different portable fuel tanks. Pumping the fuel bulb doesn't seem to help. The internal fuel filter is clean. <br /><br />I'm thinking a fuel problem, maybe the fuel/VRO pump (it's the original pre-alcohol gas version), but that's pretty expensive to replace on a guess.
