2000-Johnson 30 HP fails for 1-2 hours
nordy
Hi, when I was on the Baltic Sea before Travemünde my engine suddenly died in a field of sea grass the other day, as one had switched off the ignition.<br />I cleaned the prop, which wasn't blocked at all and then could start again and the motor ran normally for 30 further seconds before dieing off again.<br />Then the motor wouldn't start for about 1-2 hours.<br />Then suddenly it started again and ran completely normal again.<br /><br />Before and after this accident the engine always had run superbly.<br /><br />Is it possible, that the powerpack has an occasional failure?<br />The motor doesn't overheat even under full load conditions.<br /><br />this
Solittle
Re: 2000-Johnson 30 HP fails for 1-2 hours
I would guess that when you got into the grass it blocked the pickup for the water pump and the motor got hot. When it cooled it would start normally.
