michiganmarty
- Aug 12, 2003
- 62
I just picked up an old 1979 15hp that was used as a kicker for a long time. This motor runs great wide open, but I need to adjust the idle speed so high the nylon adjuster nearly falls out of the knob. <br /><br />This motor does idle, but misses a lot. I put new spark plugs in it - gapped at .030". It will idle slow enough to troll, but again, it misses a lot.<br /><br />According to the design, I should be able to adjust it down in a postion that would depict a lot slower engine rpm than I can reach. The idle speed setting it is at now, would suggest a very HIGH idle speed.<br /><br />I believe the idle jets are plugged. Any ideas out there? How to clean them? Use fine piano wire, carb cleaner, air nozzle?
