When replacing the Cranking Motor Relay, I discovered that the battery negative is used to energize the Relay.<br /><br />Why did the Manufacturer use this method rather than energizing the solenoid from the battery positive? <br /><br />Were they trying to save the cost of a wire? <br /><br />Was it a form of safety? Or what? <br />They certainly did not save wire, because the negative ground is as accessible as the battery Positive.<br />anders1@telusplanet.net
