  #1
Old October 14th, 2003, 05:56 PM
Kickin Bass Kickin Bass is offline
Default Disconnect upper shift rod linkage 1980 35hp Evinrude?
My manual is unclear on how to do this.I replaced my head gasket and am trying to replace the impeller. I separated the shift rod at the water inlet screens and dropped the gearcase. I took the water pump apart but I can't slide the water pump plate over the keeper nut on the end of the shift rod. I assume that I need to unhook the shift rod at under the powerhead??Also the water tube came out of the powerhead.Do I need to use a sealer when re-installing it.Thanks in advance, Andy
  #2
Old October 14th, 2003, 09:05 PM
Walker Walker is offline
Default Re: Disconnect upper shift rod linkage 1980 35hp Evinrude?
I did one once. If I remember right you need to slide the nut up and remove the plastic compression sleeve then the bolt will come off. Putting it back together is just reversing the order of disassembly. You don't need any sealer on the water tube, just make sure the rubber grommet at the powerhead is in the proper position and the water tube slides into it without displacing it.
  #3
Old October 15th, 2003, 08:32 PM
Thanks Walker!Your reply was right on.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
shift rod disconnect on 88 hp 1990 Evinrude Herb Ruschmann Johnson & Evinrude Outboards 9 September 29th, 2006 12:21 AM
Shift linkage disconnect olecarman Mercury & Mariner Outboards 4 January 11th, 2005 01:37 PM
Shift linkage disconnect 86 225 Johnson v12mac Johnson & Evinrude Outboards 10 October 24th, 2004 01:37 PM
..and exactly where to disconnect the shift linkage willtill Johnson & Evinrude Outboards 7 December 11th, 2002 03:32 AM
6hp Evinrude Shift Rod Disconnect work4bait Johnson & Evinrude Outboards 5 March 23rd, 2002 05:00 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
